Re: Farmall 450 Gas Tachometer plastic gear
Posted by D Slater on January 15, 2012 at 15:52:02 from (184.15.10.192):
In Reply to: Re: Farmall 450 Gas Tachometer plastic gear posted by Tony_Idaho on January 15, 2012 at 13:18:28:
Tony can't remember for sure now. Think I reduced the shaft size at the first diameter behind the gear and shimed behind the gear face.
I fixed that tractor to sell so don't know the long term results. Had several old housings and several of those were worn enough that the gear would go in but way to loose. Think I just chucked shaft in a drill and used a file and emory cloth to do it.
Good thing I write some things down because I was wrong. Reduced first diameter behind gear .026. left middle diameter the same. Reduced next diameter .033. All depends on what your housing measures on how much though. Two notched housings were used. First one was so soft it would wear fast. Next one was harder and sized more acurate. Two plastic gears were also used before the steel shaft. Last plastic gear shaft was .002 smaller diameter. Box I got the last steel shaft gear in is 369695R91. IH used to sell the gear, housing and retainer all together under #369694R91. Don't think the housing 369692R1 or retainer 369693R1 is available anymore.
This post was edited by D Slater at 16:59:25 01/15/12.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
