Re: Hiniker cab #1300
Posted by Paul in MN on January 15, 2012 at 18:18:53 from (174.20.143.237):
In Reply to: Hiniker cab #1300 posted by Dan(wi) on January 15, 2012 at 06:49:34:
Dan,
Some years ago my son and I installed a 1300 Hiniker on our Ford 9000. I'd sure guess that you are right about the weight. It is a very substancial ROPS tested cab. For install purposes, I'd take off the doors and rear window to shuck some weight. I hope you got the correct brackets to fit your tractor, as they are pretty heavy built also. Good Luck!!
Paul in MN
