Re: Farmall 450 Gas Tachometer plastic gear
Posted by AJB-830 on January 15, 2012 at 20:42:31 from (50.105.149.123):
In Reply to: Farmall 450 Gas Tachometer plastic gear posted by Tony_Idaho on January 15, 2012 at 11:57:32:
About 10 years ago I also bought two tach drive gears from Bates Corporation. I think they were metal. I used one on a 450-D without changing the housing. I will check my spare and see if it is metal or plastic. So at one time they did have a direct replacement. Al
