Re: Farmall h rear end fluid weight?
Posted by TomH in Pa on January 16, 2012 at 10:38:10 from (184.5.173.141):
In Reply to: Farmall h rear end fluid weight? posted by Ray.haapala24 on January 16, 2012 at 09:38:08:
There are four plugs related to rear end fluid (90wt gear lube):
Filler plug is near your left foot as you sit in the seat
Level check plug is on the left side, kind of under the clutch pedal
Big drain plug is at the back under the PTO shaft
Smaller drain plug is on the bottom of the transmission case near the pulley.
