Re: 460 D sleeve
Posted by rustred on January 16, 2012 at 15:50:28 from (74.200.18.156):
In Reply to: 460 D sleeve posted by tntleake on January 16, 2012 at 12:09:19:
make sure the bore is good and clean. i would try the sleeve some to see that it goes in with resistance before freezing it. it should take a good push for it to be right. too loose is no good as it will break off the top and be pulled down. thats why some people use loctite on them. you need to check the stand out at top of sleeve. all 6 should be within .002 of each other.the spec is .003-.007.
have you removed valves from head to check valves and seats and guides?
