Re: 1086 electrical question
Posted by Intl385 on January 16, 2012 at 16:25:13 from (173.242.241.246):
In Reply to: 1086 electrical question posted by Intl385 on January 14, 2012 at 19:21:25:
Thanks for the info men, problem solved. The fuse was hot on both ends but the spade lug at the end of the fuse block was only hot part of the time. I put a new wire on the lug on the other end, installed an inline fuse & fixed it to the wire going to the instrument cluster & all works well.
Thanks again,
Dave
