Re: M power steering
Posted by glennster on January 16, 2012 at 17:36:44 from (99.90.9.153):
In Reply to: M power steering posted by musky11 on January 16, 2012 at 15:15:36:
the smaller pulley will speed up the pump like smoknbs posted. also did you bleed the system? jack up the front of the tractor to get the wheels off the ground, with the engine running, turn the steering wheel lock to lock 4 or 5 times slowly. recheck your fluid level, then set the wheels back on the ground and try it.
