Re: Farmall A needs a lift
Posted by gene bender on January 16, 2012 at 18:22:42 from (67.55.227.172):
In Reply to: Farmall A needs a lift posted by Machine249 on January 16, 2012 at 17:37:57:
All depends on whether you want it original. You sure could get a hy pump and then lift the plow with hy system. You would need a cycl with little longe stroke than the common 8in but you could change the lift on the plow to raise and lower. First you need to find the mounted plow for that tractor then go from there.I have the parts and repair the exhaust systems but a hy cycle sure can do the same only need a single way system for the lift as the wt of the plow will lower easy.
