Re: Farmall A needs a lift
Posted by mkirsch on January 17, 2012 at 06:00:17 from (64.80.110.74):
In Reply to: Farmall A needs a lift posted by Machine249 on January 16, 2012 at 17:37:57:
From what I've learned, most implements on an A came with their own lift systems. Usually a hand lift.
The problem these days is most of that stuff has been lost and/or scrapped. If you can find a COMPLETE original plow setup for a Farmall A, you've got a real treasure on your hands.
There's a lot more stuff around for the Super A because the setup was much simpler due to the addition of the "universal" hydraulic lift system. Not as many parts to lose.
If you're willing to go to the expense and trouble, you might want to consider fabricating a system that emulates the Super A Touch Control setup, with a rockshaft style lift mechanism under the gas tank.
