Re: some quick work on the H
Posted by nc super c 1 on January 17, 2012 at 08:30:07 from (71.70.188.214):
In Reply to: some quick work on the H posted by soundguy on January 17, 2012 at 06:51:23:
dont touch the reg.as of yet being 12v may need a extra wire and switch to show charging cond.it needs to be exicted as you would a alt.I am not near my H were I can tell you the right I can you this one hooks from extra switch to amp gage.if its mag. ign.if not can be hooked to batt. ign.switch since mentioned coil then do not add extra switch.I will be back this eve. with info. welcome to the H&C ser.those wt.are 145lbs ea.acording to IHs manuel JOHN.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
