Re: Anyone ever replaced starter solenoid on ih 454 gas
Posted by Rich in IN on January 17, 2012 at 11:26:14 from (75.146.127.110):
In Reply to: Anyone ever replaced starter solenoid on ih 454 gas posted by PRTZMAN55 on January 17, 2012 at 09:25:07:
If starter is Delco, try turning solenoid battery bolt 1/2 turn. Disconnect battery ground cable, then remove all wires from solenoid battery bolt. Loosten second nut out to about 4 threads from end of bolt. Push bolt in and turn 1/2 and pull back out, is square shoulder inside like a carriage bolt. Tighten nut, replace all wires and nut. Hook up ground wire and try it out. Lots of Delco solenoids can be fixed this way as large terminal washer always wears one side of bolt head and other side is like new. Worth a try.
