Re: 1941 H Farmall Brake Repair Question.
Posted by Bill in NJ on January 17, 2012 at 15:38:52 from (166.248.138.64):
In Reply to: 1941 H Farmall Brake Repair Question. posted by Vinnie L. on January 17, 2012 at 13:34:46:
First of all you need to determine why the brakes are 'weak'. They might just be out of adjustment. Remove the covers and look at the linings. If there is less tahn 0.03" of lining anywhere on the band I would replace. If there is enough lining follow the adjustment procedure at the end of the message. It really isn't that difficult a job. Pretty basic mechanical stuff. The only 'tricky' part is final adjustment. There is a screw at the bottom of the cover. Turn that screw in until it will not go any further, then back it off 1/4 - 1/2 turn. Now you can adjust the pedal adjustment for your final setting.
