Re: Farmall 450 Gas Tachometer plastic gear
Posted by farmallhal on January 17, 2012 at 18:41:57 from (71.49.67.58):
In Reply to: Farmall 450 Gas Tachometer plastic gear posted by Tony_Idaho on January 15, 2012 at 11:57:32:
Tony, Was looking at eBay this evening and I came across a new listing that ends in 7 days which appears to be the part you are looking for. The item no. is 280808631473. Do a search using the item no. or on Farmall 450 tach drive and you should be able to find it if you are still looking for one. Good luck, Hal.
