Re: Super A Carb troubles
Posted by rustyfarmall on January 18, 2012 at 07:18:40 from (216.248.71.224):
In Reply to: Super A Carb troubles posted by Mike1972chev on January 17, 2012 at 11:35:00:
Are you using the choke because the weather is now cold, and when the A started GOOD the weather was warm? These old Farmalls do not like to be choked. My suggestion is engage the starter and get the engine turning over, and then use just a little bit of choke if needed to make it fire.
