Posted by Janicholson on January 18, 2012 at 11:20:38 from (199.17.6.44):
In Reply to: Help needed posted by WD FFA Farmall H on January 18, 2012 at 10:45:03:
Rusty is correct on the packing screw. The idle mix is near the top. If adjustment does nothing, the passages may be plugged going to the idle ports Pulling the mixture screw out and applying a touch of carb spray might blow it clean, but if not it will need to come off to be cretain it is clean. A low float setting can also cause the issue, as can a manifold leak to air. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
