Re: changing Disc blades
Posted by Janicholson on January 18, 2012 at 14:46:32 from (67.72.98.45):
In Reply to: changing Disc blades posted by brokengun on January 18, 2012 at 09:38:16:
I would put a 4X4 along the frame over the top of the gang I was going to remove, supported on crossing 4X4s to hold it up on the frame. Then use 3 ratchet straps over the 4X4 and under the shank. Remove the bearing caps, or mounts, and lower the gang to the floor. If it is not high enough, I would first raist the whole disk and put it on cribbing to allow removal of the gang. roll it carefully as it can cut off toes on the concrete. Jim
