Re: New Tractor!
Posted by Corky on September 08, 2000 at 02:58:05 from (63.22.8.40):
In Reply to: New Tractor! posted by AGEN on September 07, 2000 at 22:01:13:
AGEN I would start with points and plugs.Along with changing the fluids also check your fuel tank for rust.As a rusty fuel tank can cause all kinds of carb headaches later on.That ought to give you a good start on things.Good luck with your new tractor.PS and make sure you clean the sediment bowl and screen on the carb inlet.
Post A Followup
: Re: Re: New Tractor!
