Re: Driver offset
Posted by Jim Becker on January 18, 2012 at 21:31:09 from (71.252.156.130):
In Reply to: Driver offset posted by ShadetreeRet on January 18, 2012 at 20:29:28:
The exhaust lift was concocted after the tractor was designed. The lift control valve was on the right side of the engine. The hose from the valve to the cylinder had to be threaded across from the right side for implements that used the cylinder mounted on the left.
