Posted by screwstick on January 19, 2012 at 07:12:14 from (174.24.15.42):
In Reply to: Wired bolts posted by Jim Paterson on January 18, 2012 at 17:21:24:
Any wire will not work, ESP not re-bar tie wire.
As Matt and Harold said, it's safety wire, and you more than likely want to look for .032. There is a learning curve for proper safety wiring; twists per inch, wiring in the tightening direction, and having no slack/space at the connection points. Safety wire pliers are also a big plus to have.
Also, there is a big difference between safety wire and an anti-tamper wire device. An anti-tamper wire will usually be copper.
So with all this, I think I'd just do as John recommends, and use Loctite. Simple, easy, cheap and just as effective.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
