Re: McCormick Deering P12 power unit
Posted by Ron W on January 19, 2012 at 17:33:00 from (208.54.35.224):
In Reply to: McCormick Deering P12 power unit posted by Nebraska Kirk on January 18, 2012 at 20:42:08:
I have both parts books. The w-12/14 uses a gas tank 26624 DEX whereas the P-12 26624DDX. Maybe the same tank?
The hoods are the same number. The w-12/14 & p12 hood is part number 27558DBX.
I have a P12 also that is missing the radiator, aircleaner, hood and gas tank, all of which I have been looking for.
I was told that alot of the p-12 power units were used as water pumps or ran oil wells. It was common for them to take off the radiator and either divert well water through them or hook them up to large open tanks so that they can run for a really long time. If they ran on gas, then a much larger tank was used, like a 55 gallon drum or if pumping an oil well, then it ran on well gas.
