Re: Farmall Super C coolant problem
Posted by Jim Gilmore on January 20, 2012 at 07:54:23 from (131.187.253.130):
In Reply to: Re: Farmall Super C coolant problem posted by BoonvilleKid on January 19, 2012 at 19:35:24:
There is a lot of speculation about the plugs. Some say they are indeed "freeze plugs" however I think this may be an innovation brought on by need. Originally the purpose was to drain the sand out of the block after casting it. When only cooling with water you could indeed potentially cause undue stress on a casting and weaken it over time if you allow the water to freeze under VERY harsh conditions. However I think that with these older systems this was not really a consideration.
