Cylinder head
Posted by Rod in MN on January 20, 2012 at 11:51:00 from (66.242.67.252):
HI Guy's working on a w400 with a c264 engine. The head is cracked Casting # 362147 What is the differents between the 400 head and a 450 cylinder head. Will it fit. Would to keep the 362174 head on the 400. Or is casting # on a 450 the same. Or dose some one have a good noncracked 400 head i can do the valve work
Thank You
Rod in MN
