Re: Need help identifing parts
Posted by RPM1941 on January 20, 2012 at 12:31:45 from (173.24.196.59):
In Reply to: Need help identifing parts posted by Dave S. on January 20, 2012 at 08:22:35:
The first 2 numbers are self align sealed bearing & lock collar, used mostly on planter press wheels, no picture ? The hyd valve is from a combine, 303/915 early. The bearing is a common part used in a lot of places by IH, idler bearings on combines, water pumps & idlers on 460/766 gas engines. The tine I dont recognize, wasnt aware IH supplied them.
