Posted by sflem849 on January 20, 2012 at 18:54:24 from (69.197.84.39):
In Reply to: farmall md fuel systems posted by jim warehime on January 20, 2012 at 18:44:07:
You can get packing material at Menards etc an repack the diesel shutoff. I have never done it, but it sounds pretty easy. Screw off the hex nut and wrap the stuff around then put it back on is the basic story. You can try tightening the hex nut. That will stop it for a while.
When you say drain cock you are talking about the drain valve in the bottom of the carb? Did you use any thread sealer on it? Is the cast Al cracked? IIRC it is a pipe thread fitting not a flage/oring/gasket type fitting.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
