Re: SMTA vs. 400/450 gear ratios and ground speeds
Posted by Wardner on January 20, 2012 at 22:56:39 from (4.154.236.168):
In Reply to: SMTA vs. 400/450 gear ratios and ground speeds posted by CenTex Farmall on January 20, 2012 at 21:58:43:
The first gear on the SMTA, 400, 450 are the same and there is no factory low-low first. However, a 560 gear set will fit and the owner can create his own low-low first. I have done it on a SMTA. I also swapped in the Farmall 560 ring and main shaft w/pinion for another reduction. When those reductions are combined with the TA low range, first gear is about half of the SMTA, 400-450 first gear in high range.
Tractor also has new 15.5 x 38 tires on new 14" rims, a pair of front wheel weights, a pair of frame weights, and five sets of rear wheel weights but it still won't out pull my 660 w/Elwood which is heavily ballasted too.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
