Posted by soundguy on January 21, 2012 at 13:39:29 from (107.41.13.186):
dinked with the H this am, then finally got to work on the C.
backed it up to the shop and had my available scrap set out. drug out the chop saw and torch and marking chalk.. started measuring what I had and layed out a basic fram that bolts tot he tractor rear, and centers above the place where the belt pulley would be, etc.
have it all vice clamped together and on the ground and will weld it next chance I get to play.
i have a pipe and round stock for the rockshaft.
I will be using some old 8n arms as the lower arms, and will use flat stock as the lift links I THINK, unless I have enough rebar left over .. most of the rebar will be linkage from the forward hyd arms.
won't be elegant.. but should be functional.
have yet to measure out the 'L' shaped brackets fro the rockshaft that hook tot he lift links and the links to t he tractor hyd.
more pics as work progresses. perhaps monday night?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
