Re: electrical trouble
Posted by soundguy on January 21, 2012 at 14:27:09 from (107.41.13.186):
In Reply to: electrical trouble posted by Ed Hotaling on January 21, 2012 at 13:05:26:
for 1, you likely have a bad connection. maybee at the ground strap to the chassie.
dropping to 5-6v on a 1 2v system trying to start is a massive drop, assuming bat not bad, then it's a bad connection or dead starter.
now.. the fact it is trying to crank and did so till you pulled the bat cable off is because due to the low voltage, the current was high and WELDED the solenoid contacts.
many times you can rap the solenoid with a screwdriver to get ti to release. some solenoids you can even take apart and clean the contacts up.. others are throw away.. etc.
soundguy
