Re: electrical trouble
Posted by Janicholson on January 21, 2012 at 14:47:48 from (67.72.98.45):
In Reply to: electrical trouble posted by Ed Hotaling on January 21, 2012 at 13:05:26:
On a totally different situation and cure potential, the Alt might have a bad diode in the rectifier bridge. This will discharge the battery to the same point is short order (pun intended). A bad regulator in the alt will also do it. A bad diode in the feed to the alt to excite it (if it is not a one wire system) will also do it. Check for battery drain when it is fully charged if you see ,5 volts from a disconnected battery cable to the post, I would suspect the alt. Pull its wire off and check it again. Jim
