Hyd lines on 460 diesel
Posted by CIH9280 on January 21, 2012 at 15:51:15 from (67.55.205.37):
I need to replace the steel hyd. lines under the seat that run the 2pt. hitch. They are not avail.from CIH. Doe's anybody have an idea where I can get the set. The serial # is above 20,000
Thanks for any help. This is a row crop tractor.
