Posted by pete 23 on January 21, 2012 at 16:51:28 from (74.32.238.142):
In Reply to: Hydro 70 Question posted by rustyacresnd on January 21, 2012 at 15:35:38:
First off , make sure the foot-n-inch pedal is not contacting the platform. It has to clear it so valve can be fully seated. Pedal must have good spring and be free. If that is ok, take off the return line fitting from that valve and put tractor under load that makes tractor stop. If oil comes out of that fitting, it means the valve is leaking unless you are reaching max pressure which I would doubt or it would pull. Maybe broken spring in valve. Next test is to cap with steel caps the two fittings coming off top of transmission to control valve. This will eliminate all external causes of problem. You will not have use of the foot pedal then so you would have to be very careful. Unfortunatly, you say it works ok cold, that sounds like worn plates causing lift off when warmed up.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
