Re: WD-9 Belt Drive Shaft Seal
Posted by plow hand on January 22, 2012 at 03:54:36 from (67.6.64.25):
In Reply to: Re: WD-9 Belt Drive Shaft Seal posted by WD9ER on January 21, 2012 at 21:23:07:
How about the long bolt (about6"long)on top if you
loosen them and try to pull them out the bolts will
hit the fuel tank.But getting them free and loose
and tilted is enough to pull out shaft assembly.That
is what I had to do..give me a call if you have any
further problems...Tom 651-22six-one103.
