Re: Farmall H Steering Post Dent
Posted by Yooper Farmall on January 22, 2012 at 08:53:55 from (68.61.186.11):
In Reply to: Re: Farmall H Steering Post Dent posted by rustyfarmall on January 22, 2012 at 08:41:20:
The previous owner drilled the hole out bigger than factory so he could insert a starter bolt. I think it would have been easier to find the correct size bolt/pin.
