Re: Farmall H Steering Post Dent
Posted by D Slater on January 22, 2012 at 09:15:13 from (184.15.6.93):
In Reply to: Farmall H Steering Post Dent posted by Yooper Farmall on January 22, 2012 at 08:24:56:
Does the dent match where it would hit the rear of the fuel tank? If so you find them like that if the steering shaft collar or steering shafts joint coupling wasn't tight enough or slipped when a big jolt happened.
