Re: Need help with Lift-All pump removal.
Posted by Eastsider on January 22, 2012 at 17:26:17 from (96.3.33.67):
In Reply to: Need help with Lift-All pump removal. posted by lbg57 on January 22, 2012 at 16:32:50:
On an M, there is not much room in the coupling. The sleeves you are talking about are on the H, not the M. Take out the bolts or pins and rotate the crank...when you get it vertical, it will be able to drop down and out.
