Re: Farmall m is a professional starter button burner upper
Posted by Nebraska Cowman on January 22, 2012 at 18:09:47 from (66.252.115.26):
In Reply to: Farmall m is a professional starter button burner upper posted by Aaron Spears on January 22, 2012 at 17:59:15:
Well, you must be a pretty good typist anyhow.
Alternators often put a small drain on a battery.
that's why the battery stayed up the week you had it
unhooked. There is a diode you can put in the line
to stop that. I suspect you have a battery ignition
distributor instead of magneto and that's what the
extra small wire coming from your starter is for. As
far as frying switches I suspect those cheap
switches are just that. Cheap.
