Re: Farmall m is a professional starter button burner upper
Posted by Dean Olson on January 22, 2012 at 20:39:34 from (98.196.66.64):
In Reply to: Farmall m is a professional starter button burner upper posted by Aaron Spears on January 22, 2012 at 17:59:15:
My 3- Super C's, 3-Super H's,300 and a previous M are all tuned
such that they start immediately, with no choke, unless it's cold or
they've sat for awhile. All are 12v with alternators.
I suggest you do a thorough check of the engine starting with a
compression test all should be over 100 psi and within 10 psi of
each other. Then check your fuel,fire, and air systems. It may just
need some maintenance.
