Re: Farmall m is a professional starter button burner upper
Posted by pete 23 on January 23, 2012 at 10:47:56 from (74.32.238.142):
In Reply to: Re: Farmall m is a professional starter button burner upper posted by Aaron Spears on January 23, 2012 at 09:12:28:
You indicate that it is a pulling tractor, that
kind of changes a lot of things. It may be pretty
high compression, timing, who knows where it is
set at, no doubt for maximum power under pulling
conditions. Far as the spark advance, that occurs
with engine rpm and totally dependent on how
distributor is calibrated. In other words, it will
advance the spark as engine rpm increases and
retard as it decreases and has nothing to do with
the throttle setting when engine is not running. I
fought 6 volt starting systems for years. The last
really hard starting gasoline engine IH made was
the first 450 gas tractors. About half way through
production they switched to 12 volt systems and
problem solved. Many M's are on 12 volts now and
most stayed with the 6 volt starter and it
works out quite well. One thing, they do not have
the initial torque to get that engine started
turning, but once it turns just a little, they
spin it like heck. Being a six volt starter it
has much lower resistance so will really draw a
heavy current for a few seconds until it gets it
turning. This is normally not a problem but with a
higher comp engine and cold thick oil it may very
well be a problem. You may want to get that
starter converted to 12 volts also if it is not.
Far as solenoids, well, if you can get a really
heavy one it is good, but most of them are no
heavier in the contacts than the original push
switch, just that they slap the contacts together
good and hard. You of course need good clean,
heavy connections all the way through and ground
the battery right on starter mounting bolt for
best results.
