Re: F-20 electric battery box
Posted by BruceS. on January 23, 2012 at 14:54:03 from (76.15.41.164):
In Reply to: F-20 electric battery box posted by oldiron29 on January 23, 2012 at 13:24:53:
I had a steel plate made with a piece welded to it at a 90 degree angle which fits up against the inside of the frame rail. Drilled two holes thru frame rail to bolt it on. Then bolted the box to the plate. You can drill slotted holes in the plate if you want so you can adjust box to your liking.
This makes for a very rigid installation...no vibration and no movement on the box whatsoever.
