Re: Fluid for transmission
Posted by gbs on January 23, 2012 at 17:08:12 from (68.115.212.154):
In Reply to: Fluid for transmission posted by Jim Paterson on January 23, 2012 at 15:22:08:
don't think i would try the kerosene and driving because it's going to put a lot off that crud,metal fillings and what ever else into suspension right into the bearings unless you remove the cover and wash it clean,other post has it right scrape as much out as you can thru the drain hole that will let you see if it's bad enough to flush,as for oil if your not in to cold of an area use the 140 gears will run quieter and don't clash as harsh when shifting, just what i have found to work for me
