Re: Super C hydraulic hoses
Posted by Lmack on January 23, 2012 at 18:36:14 from (98.66.240.9):
In Reply to: Super C hydraulic hoses posted by J.D.HEICHEL on January 23, 2012 at 13:03:46:
If you only replaced the hoses from the block at the front of the seat support to the cylinder, there is only two ways, right and wrong, but the wrong way will not damage the unit. If you hook it up backward, the cylinder will function backward, that is when the control lever is pushed forward the cylinder will go down. If pushed forward it should go up. If on the first try it happens to be wrong, simply reverse the hoses at the cylinder.
