Re: finally started burning rods on the C 3pt
Posted by Armand Tatro on January 23, 2012 at 20:12:31 from (98.227.26.140):
In Reply to: finally started burning rods on the C 3pt posted by soundguy on January 23, 2012 at 19:00:22:
Looks like Wardner posted a few minutes ahead of me. Follow his ideas and you will have a safe and dependable hitch that you can be proud of for years to come.. As he says the parts are aviable off the shelf. Armand
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
