I can't say for sure since you do not have the factory three point. But on a Farmall model with 3 point, to the right of the seat as you are sitting in it, down by the remote valve, sandwitched between the remote valve and the lift cylinder housing (raised smaller rear end cover casting that seat mounts to), there is an adaptor plate. stand on the drawbar and look at this plate, there will be about a 1 inch hex head pointing at you on the top side of this plate. probably different on non 3 point model, likely similar? I don't have time to check the parts site at the moment, but you could try yourself. caseih.com "parts and service" then click on something to the effect of "look up parts" and then you can type in your model. don't use the online parts store, it's not so handy for research purposes.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
