Re: 51 H Transmission Metal Chunks
Posted by CoopertownBob on January 23, 2012 at 21:20:47 from (74.51.5.124):
In Reply to: 51 H Transmission Metal Chunks posted by glennster on January 21, 2012 at 16:00:22:
Quite possibly it is the pilot bearing on the front of the top shaft where it rides inside the front constant speed gear mechanism. Easiest way to tell is to just grab the top shaft at the front and shake it to see if it is loose or clutch it so you can turn the constant speed gear by hand and listen for any grinding noises. It is a needle bearing in there, and they can be a bear to diagnose. On the good side, they are super simple to fix, as all you need do is pull the drive shaft, pull the front cover (done from underneath), and the bearing will be readily apparent for all the world to see! And, it is the first thing you remove when pulling out the rest of the transmission anyway, so if you pull it and it is fine, you've not wasted any effort since it had to come out anyway.
If I am remembering right, there are a total of nine bearings in there. Two each on the top shaft and bottom shaft, one on each end. One on either side of the differential carrier that can be pulled out by removing the bull pinion shafts from the sides, but be careful pulling the bearing cages, as they are plain cast and you can easily break an ear off where the pulling bolts screw into them at, (don't ask me how I know this :oops: ). The ones on the inside ends of the axle shafts, accessible by dropping off the bull gears and then removing the four bolts in the circular retainers holding them in. And of course there is the above mentioned pilot bearing.
I actually had a noise problem in mine, along with the bits and pieces of "something" coming out in the oil, and when I pulled it apart, the pilot bearing came out in several pieces, but turned out that was only part of my problem. One of the spider gears turned out to be missing large chunks of several teeth as well. Good news however, I used that as an excuse to replace every bearing under the rear frame cover, along with all the seals too, and I found another issue that required a replacement part as well, that I would have missed had I not pulled everything out in the process.
