Re: 650 Injector seals
Posted by Andrew Z on January 24, 2012 at 09:24:32 from (64.252.124.124):
In Reply to: 650 Injector seals posted by plow hand on January 24, 2012 at 08:41:37:
replace them, they are around $3-4 a each. Make sure you get the correct ones two diffrent ones were used. (early vs. late)
Andrew
