Re: 240 Farmall hydralics
Posted by cd1 on January 24, 2012 at 09:46:52 from (67.239.40.217):
In Reply to: Re: 240 Farmall hydralics posted by BBinOK on January 24, 2012 at 06:55:50:
I'd take a look at the linkage running from the hydraulic blocks under the dash back to the fast hitch, it should be moving with the fast hitch and controlling the valve under the dash to set the position, I have to think you have something broken or unhooked in that system. The transmission has no filter itself. There is a filter for the hydraulics but it is in with the rest of the stuff under the dash. The transmission and hydraulic oils are separate.
