Re: Farmall 450 Gas Brake issue
Posted by Mike1972chev on January 24, 2012 at 10:28:34 from (75.149.81.173):
In Reply to: Farmall 450 Gas Brake issue posted by Tony_Idaho on January 24, 2012 at 10:03:26:
Common problem with these.
Yea,a LITTLE lube on eack of the balls will help MUCH,but if they are pitted at all,I would replace. I put new chrome plated ones in mine and it was ALL the difference!
Probably stupid question,but did you clean the grooves in the seperator plates really good with sandpaper/wire brush wheel??
Also,lastly,sand the surface of the plates where the brake disc hit with 220 grit.Sand ACROSS the surface,NOT in a circular motion around it.You might slightly scuff up your brake disc too.BARELY rough them up.
It will stop %200 better afterward.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
