A couple additions to Mike1972chev's excellent suggestions:
THOROUGHLY clean (wire brush) the brake shaft splines and the friction disk female splines. If there's any burrs on the splines carefully file them smooth. Before reassembling lightly lube the splines with motor oil or light grease (apply lube sparingly on then wipe off as much as you can with an old towel - you want to leave just a film).
Also clean (wire brush or sandpaper) the areas where the center disk anchor dogs bear on the covers. Then lightly lube as above before assembly.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
