Well, Armard, I don't know where you got your Engineering Degree, but you are totally wrong on rebar "being thrown together with different grades of iron". All rebar made in the USA is made to ACI Standards. If above #5 size, it is 60,000psi steel. Which means, it should never be used in conjunction with light-grade angle iron, which is, at best, 30,000psi. Rebar cannot be "properly" welded unless it is heated to the proper degree of heat prior to welding and to the proper degree of heat after welding. A good welder can weld rebar, but without using the ACI methods it sometimes holds and sometimes it comes out like crystal candy - brittle. Don't use rebar for what it's not intended to be used for - for reinforcing concrete.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
