Re: H 12 volt conversion
Posted by Keith-OR on January 24, 2012 at 17:31:24 from (75.164.157.244):
In Reply to: H 12 volt conversion posted by Jim Paterson on January 24, 2012 at 16:08:52:
The way I put 10si on H, is I took the factory generator bracket off engine turn it over and bolted it back on, then I use althread to line up the alternator pulley up with motor pulleys. Fit fine under hood. If I still had the H, I would take pictures for you.
I can't remember if I use the generator adjustment arm, or made one to fit. I won't cut any sheet medal!!!
