Posted by jal-SD on January 24, 2012 at 19:21:30 from (208.53.222.169):
In Reply to: H spindle seals posted by Senator on January 24, 2012 at 19:06:13:
Put the wheel over a five gallon bucket with the seal/bearing side down that you want to remove. Use a long punch and LIGHTLY give the bearing cone a tap or two from the other side, then move the punch about 1/2 inch on the cone and repeat the process. Continue until the bearing cone and seal come out. (You can remove the bearing cup the same way if it needs to be replaced, but that will take more than a light tap or two.) The seals are not too expensive, so if it looks bad replace it when you repack the bearings. Dust seals are a lot less expensive that new bearings. (My $0.02 worth. jal-SD)
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
